dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description
This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to USB cable.
Advantages:
* VMware player be downloaded freely
* Can run in both existing linux / MS Windows (XP,Vista etc) operating system without any further modification
Disadvantages:
* Requires a SATA to USB cable
* Mac users will need to find another program to run the VMware files
Background
At some point your ReadyNAS Duo unit is going to stop working (which hopefully will be long and far into in the future) and there may be a point where you'll need to rely on your external backups.
While it's a good strategy to ensure you (and your family / clients) have a good disaster recovery process (having external off-site backups, checking the backups, knowing how to restore from backups etc), in some cases the backups might not work or the backups aren't available to you.
Due to the architecture of the ReadyNAS Duo (more specifically the 16KB blocksize of the partitions), you cannot simply pull out the hard disks, place them into a standard windows / linux pc, then copy all your files across to another computer or storage device.
Unfortunately there are no windows drivers that can properly access the drives and the process to configure a linux pc is complex (see viewtopic.php?f=25&t=24861&hilit=16+blocksize for further background on this)
The following VMware images contain all required patches to read your HDDs in linux just by entering a few terminal commands.
VMplayer Link
To get started, you will need to download a version of VMplayer for your operating system Win/Linux (Mac not directly supported yet), this can be found
http://www.vmware.com/products/player/
VMware Linux Image with Ext2Fuse
acmtn Debian release - tested ok, reports are that it works fine except for files greater than 4GB)
http://www.readynas.com/contributed/dek ... ebian5.zip
acmtn VM login info (username/password): root/rootadmin, vmuser/vmuser1
(please read the forums for more details on how to use this vmware )
_vito Ubuntu release - currently being tested, enables you to use the HDDs directly plugged into your pc without the need for a SATA to usb cable.
http://www.readynas.com/contributed/dek ... buntu9.rar
Details on this alternative vmware can be found on this post (you'll need to review the instructions carefully):
viewtopic.php?p=203653#p203653
dekkit Debian release - tested, a number of issues.
my initial attempt that helped start this thread has been found to have quite a few issues and may not work for you, but can be found here if you would like to try:
http://www.readynas.com/contributed/dekkit/VMwareDebian5.0%20-%20ext2Fuse.rar
dekkit VM login info: User: vmplanet pass: vmplanet.net
the acmtn version at this stage appears to be getting more reliable results for users. Unfortunately, I have not had time improve on my original dekkit release due to time constraints but if you would like to try please post your results.
Dekkit release Notes:
* You will need 8GB of free disk space once you have uncompressed the image
* You will still need to execute some of the terminal commands to mount the drive (take precaution so you don't accidently blow away your data)
* This VMware can access other windows file shares and can also be configured to host windows shares (see the docs for debian for more info on this)
* To uncompress the file use WinRar: http://download.cnet.com/WinRAR-32-bit/ ... 07677.html or for non-windows platforms try: http://www.rarlab.com/download.htm
* This image is a work in progress (WIP) so please post all errrors !!!!!.
Dekkit release Usage- this may apply to the other versions (eg acmtn
Login to the OS
Access the terminal and enter the following once the HDD has been attached (take note that your /dev/c may differ):
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
ext2fuse /dev/c/c /mnt/lvm
there is a delay in output but then ..
"/dev/c/c is to be mounted at /mnt/lvm
fuse-ext2 initialized for device: /dev/c/c
block size is 16384"
Dekkit Release Acknowledgements
The original VMware image was found http://www.vmplanet.net/node/85 (before the various patches were applied - so feel free to drop them a donation), if you can improve this image by way of a script to make it even easier to use for us 'non-linux users' then please do so and share it back with the rest of us
Advantages:
Disadvantages:
Background
VMplayer Link
Login to the OS
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
- flacflexAspirantHi to you all and thanks for your work !
...and especially to VITO and his vmware image.
After dowloading,
I just have a small problem to boot with it :
After booting in the ubuntu menu,
I get a boot msg problem :
___________
Gave up waiting for root device. Common problems:
BusyBox v1.13.3 (Ubutuntu 1:1.13.3-....
____________
Any solution ?
Thanks for your help.
Flex :D - flacflexAspirantOOps
sorry.
There's an explanation in a little TXT. file.
Thanks :roll: - GhostfaceAspirantAs this was one of main threads i found when googling my problem I'd thought I'd post in here.
My readynas died and I no longer had access to my files. I tried for ages but eventually stumbled across this progam called R-linux, recovered all files including file names and folder structure. Winner. - xtrips1AspirantHello,
I have another thread open in this forum for a week now and also a case at Netgear.
The situation is as follows:
- ReadyNas Pro, 6 X 3TB HDDs, Xraid2 with one HDD for redundancy (RAID5 + autoX, right?), 7 TB worth of data, Journaling disabled, Recycle Bin disabled.
The problem:
- accidentally deleted the media share, therefore all 7TB disappeared (Huge catastrophe for me!)
I have been waiting for Netgear's support for a week now to provide the necessary parameters in order to be able to run R-Studio on my HDDs, connected to a PC at the moment. And I am still wating (so much for efficiency).
Can this solution here help me? (just to remind you, I deleted the files!)
Note: I ran a regular undelete tool for EXT partitio on one HDD, in read only mode, scanning. It came up with a HDD full of data of all sorts. Filenames were just generic and numbered, but accessible. Of course a JPG for example would show only a small part of the picture since the rest is spread across the 5 other HDDs.
Thanks - xtrips1Aspirant
xtrips wrote: Hello,
The problem:
Thanks
Bump!
Is this thread alive?
Can somebody tell me if this solution is suitable for me?
Again: ReadyNas Pro, 6 X 3TB (terabytes) HDDs, Xraid2 one hdd redundancy.
Ghostface wrote: As this was one of main threads i found when googling my problem I'd thought I'd post in here.
Hello
Which RAID type were you using?
Which product from R-tt did you use?
Which parameters did you use in that product to reconstruct the RAID?
Thank you
I am here: http://maps.google.com/maps?ll=32.111453,34.830816 - pc_addiictAspirantthe username and password for debian logon is incorrect
in any combination doesnt work!!!!
bloomin frustrated need to get my DATA!!!!!!!!! - elgbertAspirant
pc-addiict wrote: Your folders and file should be listed (if all goes well) in this terminal, you can now copy them to another HDD (usb, share etc that you have connected to the VMWare). Be aware there is a 4GB file limit on each filesize (a limitation of the ext2fuse).
I am using Ubuntu with fuseext2 as described here
http://home.bott.ca/webserver/?p=306
all was going well and I was getting my data, but I can not read files >4GB from my Duo drive. I can see from terminal that the directory sizes are listed correct, but they are not the sum of the file sizes. File sizes are listed as max 3.8 GB. I have tried to zip them with 2GB split, but the problem is reading them.
How can I resolve this? I really need my video files >4GB. - mjw1AspirantFor anyone who has working disks but a failed Readynas unit and is trying to get the data out, here's how I eventually succeeded doing this
- jausenbaughAspirantThank you! Thank you! The network adapter went out on one of my client's ReadyNAS Duos, and there was new data since the last backup. Using the acmtn Debian release, I was able to mount a volume from one of the mirrored drives hooked up via a USB to SATA adapter and copy data off. The only issue I had was not being able to browse the mounted volume from the GUI. So all of the browsing, copying, etc had to be done via the command line. Not a big deal, but I am not too experienced with Linux. Very relieved that this worked!
