yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- GlobalMindAspirant
johlar wrote: Hi.
I am using Western Digital WD10EADS-00L5B1 1TB disk in my ReadyNas Duo and it works fine.
I have had no problems with it, and the temperature is "normal".
Tought you should know so you can add this to the compatibility list;)
What code level on the Duo are you running? - trukli58AspirantHello
Thanks for the compatibility list. But regarding printers it is pretty poor... I have an HP Laserjet 1018 - it works only if i first plug it in directly to the USB Port of the PC (Windows XP). When i turn off the power of the printer it is still recognized from my ReadyNas Duo and PC, but no chance to print, nothing happens, no error message - nothing. Plug the printer directly to the USB port of the PC again, make a testprint, replug it again on ReadyNas (leaving power of printer on!) - works again.
With my new Samsung CLP-315 everything works fine.
I intend to buy a new black/white laser printer but this compatibility list does not really help me a lot. I have found an interesting compatibility list for the Fritz!Box printserver on http://www.wehavemorefun.de/fritzbox/Drucker. For my HP 1018 exactly the same incompatibility issue is described, so i wonder how far this list could be used for the ReadyNas. Anyway. I have started a support request and the answer was to post here in the forum my whish for an actual and significant printer compatibility list. I think that the Fritz!Box list could act as reference...
regards //kurt - Retired_MemberHow come the ReadyNas X6 is no longer on the list? We were some of the original users of this device and now we are taken off the compatibility list? http://www.readynas.com/?page_id=82
Please explain! - chirpaLuminaryIf it works in the NV, it will work in the X6/600.
- schalliolAspirantI was thinking about buying some 2TB Seagate Constellation ST32000644NS drives. I currently have and have been happy with the Barracuda ES 750s in my NV+, and for 2TB drives, the model I've listed above seems to be the "replacement" model. I see that they are listed as compatible on the ReadyNAS NVX and Pro models, but they are not listed for the NV+. Does anyone know why they might not work in the NV+ or whether they just have not been tested and should likely work? If they were listed, they would be the only 64MB cache and Anti-vibrational 2TB drive with a 5 year warranty.
Thanks! - jdh500AspirantJust take a chance and install some of the drives not on the list that other have had success with anyway. Surely anything that is critically importance you backup on a seperate portable USB drive ? I currently have an NVX with 4 x 1.5TB Samsung drives and a Duo with 2 x 1TB drives in Raid 1 for backup and I use a couple of original 500Gb Seagate drives that came with each NAS as USB backup.
I've been using Samsung drives ie, 1TB and then 1.5TB eco drives over the last 2 years without a problem, I had a problem with one of the original Seagate drives that Netgear included with the Duo.
JDH.thehyecircus wrote: As someone who JUST got their ReadyNAS Duo today, this compatibility list is horrid. Most of the drives on here are from 2007, and I am trying to find drives at my local Best Buy to avoid having to ship them (as I have been told that can lead to drive failures).
The problem is, very few drives are at Best Buy, and zero of them are the ones I am looking for. I am sure, if it was updated more frequently, more drives available for purchase now would be available. As it stands, I think I am going to have to take the hour drive to MicroCenter. - schalliolAspirantThanks for the message. I actually did buy one anyway, but I am going to use it for another purpose (mobile backup) for a while. My plan is to wait until the price drops and buy 2 more (eventually total of 4) to put in the NAS.
- ernie29AspirantAny reason why my Netgear WGT634U router would not be compatible with the ReadyNAS device? I realise it is not on the compatibility list, but only 11 Netgear switches or routers are on the list, so I assume that more will be compatible. Keen to know before buying one.
- PerssonAspirantWell thought that I would add to the now 2 year old inaccuracy of the HCL list.
the APC CS 500 is reported as incompatible with a NVX by a user mash .
Today tested my APC CS-500 after having received the P10C10 to USB cable part number 940-0127E FCI
NVX with RAIDiator 4.2.11
- The log did not detect the connection of the UPS via the cable (the only problem)
- the Green indication litt up
- hovering the mouse over the light gave status information " APC CS-500 , 100% , 51 min"
- health information showed the same information
- Janking the power cable, caused a log entry, a display alert and a email message to be sent with on "battery power"
- followed the battery level sink for 15 min on the NVX admin interface.
- reconnected, another log entry "on line power", alert on "web display" and an email sent that power is ok.
(The log entry "power ok" is indicated with a flashing yellow light which you might argue is wrong it ought to be a green steady....)
only thing not tested is that the NVX initialises a shutdown at low battery, will do that a bit later.
So....searching through the forum, one user says that a firmware update a couple of years ago sorted this Cs 500 problem....
i would agree with that.... - cuccuredduAspirantI also wanted to report that the APC Back-ups CS 500 is compatible.
In my case, I have a ReadyNAS Duo. I am running the latest version of RAIDiator (4.1.6)
At first I thought the device was not compatible, as it took a while to detect it (or at least, for it to show up in Frontview). However, after 15 minutes or so, the UPS indicator in Frontview turned green, and Frontview displays "APC Back-UPS 500, Battery charge: 100%, 43 minutes" in the status page. I also tried disconnecting the power and the RND correctly detects this sends me alerts for when the UPS is on battery and then again when it's back on mains power.
The current hardware compatibility list shows it's not compatible, so I suggest it's changed to reflect my experience and that of the post before me, given that it seems to work both with RND and with NVX.
Thanks,
Rob
