rocus
May 29, 2014Aspirant
Readynas Duo crashes (or hangs) on big filecopy
My Readynas DUO crashes consistently while copying a large file. The first time I copied a video file (300MB) from one place on the NAS to another (on the NAS) by means of a NFS share and Nautulus on ...
May 29, 2014Guru - Experienced User
I don't see anything concerning in the SMART stats. Reallocated and Pending Sector counts are 0, and they are the most useful stats for determining drive health. ATA errors have multiple causes and are worth a closer look, but you don't have any.
Hardware ECC Recovered and Raw Read Error Rate have vendor-specific formats, and without knowing the specific way Samsung formats those parameters it is not possible to analyze their significance.
In any event, if there had been a write error to the drive, the reallocated sector count would have increased. If there had been a read error from the drive, then the pending sector count would have increased. Neither happened.
If you have SSH installed, you can try copying from the command shell - which might help you isolate the problem if it begins to happen again.
