rocus
May 29, 2014Aspirant
Readynas Duo crashes (or hangs) on big filecopy
My Readynas DUO crashes consistently while copying a large file. The first time I copied a video file (300MB) from one place on the NAS to another (on the NAS) by means of a NFS share and Nautulus on ...
rocus
Jun 01, 2014Aspirant
The root partition is only half full. (df)
I googled ofcourse the error message and came to the same posts as you. They all seem to focus on network issues. I think I ruled that out because the problem also occurred with hardly any network traffic.
I see a suggestion about memory. How do I do a memory test?
The next time the problem occurs, and is reproducable, what should I do/try to narrow down the problem?
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/hdc1 2031872 933376 1098496 46% /
tmpfs 16 0 16 0% /USB
/dev/c/c 970385648 571441264 398944384 59% /c
