rocus
May 29, 2014Aspirant
Readynas Duo crashes (or hangs) on big filecopy
My Readynas DUO crashes consistently while copying a large file. The first time I copied a video file (300MB) from one place on the NAS to another (on the NAS) by means of a NFS share and Nautulus on ...
Jun 01, 2014Guru - Experienced User
http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf pages 15-16
rocus wrote: How do I do a memory test?
Check the SMART stats and run fsck to start with.
The next time the problem occurs, and is reproducable, what should I do/try to narrow down the problem?
