rocus
May 29, 2014Aspirant
Readynas Duo crashes (or hangs) on big filecopy
My Readynas DUO crashes consistently while copying a large file. The first time I copied a video file (300MB) from one place on the NAS to another (on the NAS) by means of a NFS share and Nautulus on ...
gregenz
Nov 23, 2014Aspirant
Hi folks, did you sort this one?
I have a similar case and also wondering if it is memory. Don't believe it used to do this, but now works until you queue up a whole lot of files and it hangs just as you have described on big files as far as I can tell. Always comes back after a power cycle, but quite quickly quits again with the problem. Something is 'hitting a limit' somewhere that triggers a major event.
Would be great to know if it has been found, tries a few changes in settings in the network link manual link negotiation etc, not helped too much. Almost feels to me like its the network I/F that falls over, but not sure why I think that. But if memory had some errors high up it could do this I guess.
Greg E
Greg E
