rocus
May 29, 2014Aspirant
Readynas Duo crashes (or hangs) on big filecopy
My Readynas DUO crashes consistently while copying a large file. The first time I copied a video file (300MB) from one place on the NAS to another (on the NAS) by means of a NFS share and Nautulus on ...
gregenz
Nov 24, 2014Aspirant
Thanks mdgm,
Yes Duo, and after figuring and reinstalling the ssh, have logged into root, and get
<8% full inodes df-i
< 24% MB on df -h
Tailed the syslog and seeing a lot of kernel: rxS1: ..... rxS0.... lines, not sure if they are significant, will try a bit file xfer and see if anything else shows.
Copied 27M - ok more rxS1 's
Tried much bigger file, died after a few seconds. Did manage to get one more tail syslog, but then a few seconds after, its dead. No ping even.
Ideas?
< 24% MB on df -h
Ideas?
