mr_yogi's avatar
mr_yogi
ReadyNas Duo v1 RAID-X Question
I have a ReadyNas Duo v1 with 2 1TB drives, however one has just died and is out of warranty, so I'm considering replacing it with a 2TB WD RED drive. Can anyone tell me if RAID -X will automatically set up the 2TB drive ready for adding another when the remaining 1TB drive dies? The remaining 1TB drive is of a similar age so I don't have much confidence that it'll last much longer either. Thus automatically creating a 2 x 2TB array?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    What version of RAIDiator?
    If you download your logs (Status > Logs > Download all Logs) and extract the zip contents what are the contents of partition.log?
  • StephenB's avatar
    mdgm is wanting to check (a) that your firmware supports 2 TB drives (4.1.8 does), and (b) if your current RAID array has 4K alignment (unknown, which is why he asked to see partition.log).
    While you can simply replace the drives one at a time, to get the best performance with 2 TB you need 4K alignment. If you don't have that already, you would need to do a factory reset to get it, and restore from backup.
    Maybe you can post the partition.log info.
  • Contents of partition.log (failed disk has been removed from system)
    Disk /dev/hde doesn't contain a valid partition table
    WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
    Disk /dev/hde: 999.9 GB, 999991611392 bytes
    255 heads, 63 sectors/track, 121575 cylinders, total 1953108616 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Disk identifier: 0x00000000
    Disk /dev/hdc: 999.9 GB, 999991611392 bytes
    Disk identifier: 0x62207372
    Device Boot Start End Blocks Id System
    /dev/hdc1 2 4096001 2048000 83 Linux
    Partition 1 does not end on cylinder boundary.
    /dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
    Partition 2 does not end on cylinder boundary.
    /dev/hdc3 4608002 1953092233 974242116 5 Extended
    /dev/hdc5 4608003 1953092233 974242115+ 8e Linux LVM
    Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
    255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
    /dev/sda1 1 1953520064 976760032 c W95 FAT32 (LBA)
  • So I assume from my partition.log my array is not 4K aligned?
    I've just ordered a 2TB WD Red, so I can just slap it in when I receive it, and he array will be rebuilt as a 1TB Mirror. Then in the future when the remaining 1TB Seagate fails I can replace it with another 2TB drive and do a factory reset to rebuild the array as a 2TB 4K aligned mirrored array?
    I've got my NAS backed up to an external USB drive, does the ReadyNAS have a simple utility to restore from USB once the factory reset has been carried out and the 4K aligned 2TB array has been created?
    mdgm-ntgr
    Yes a factory reset would be needed for 4k sector partition alignment. You could use Frontview backup jobs to restore your data from backup.
ProSupport for Business
