hedgemonk
Oct 27, 2012Aspirant
ReadyNas NV+ and iphone 4s
Hi, I have recently bought a readynas NV+ which works well with everything in the hjouse, laptops, ps3 etc. However, i can not get it to pair with the iphone or android phone. Readynas remote just ...
Nov 01, 2012Guru - Experienced User
With Android I've had good luck with ES File Manager (as noted above). For use over the cellular network (or while away from home): Part of the puzzle is configuring a suitable port range on the ReadyNAS and forwarding those ports in your router. Also you would want a dynamic DNS name for your router. Though if it works with your laptops, that is probably already in place?
We don't have iPhones, so I can't speak to that.
ReadyNAS Remote is also supposed to work, though I haven't used it in quite a while (and there are some recent posts here indicating that it is not working properly at the moment).
