sridgway
Jan 15, 2013Aspirant
ReadyNAS NV+ Disk Failure
I have owned a ReadyNAS NV+ for over 4 years and it has never missed a beat since I set it up.
it was setup up with 4 x Seagate ST31000340AS 1000 GB Hard Drive
Late last year I began receiving error notifications from the NAS regarding disk 1
Disk 1: Previous count: 7
Current count: 8
This went on for a month or so finally increasing to
Disk 1: Previous count: 931
Current count: 1710
At which point I received a notification that Disk one had failed
Disk fail event occurred on SATA channel 1.
No worries I thought, I'll get a new 2 Tbyte replacement so I purchased a New drive Seagate ST200DM001 2000 GB which is listed on the compatibility list
Saw a few pots regarding having the latest firmware so I checked it did seatools reported Firmware CC24
I put the drive in and all seemed fine and received the initiation notice
Disk initialization started.
The next day all seemed fine
RAID sync finished on volume C. The volume is now fully redundant.
but a minute or so after accessing the drive I received the same failure message "Disk fail event occurred on SATA channel 1." and I was back to square one :<
Have powered down and gone through the process again the same thing happens.
Has NAS channel failed or should I try another drive brand on the compatibility list??
Any recommendations welcome
Current count: 8
Current count: 1710
- StephenBGuru - Experienced UserI google the forum to get the user experiences on the disk model before I buy. Experiences with ST2000DM001 are "mixed" Personally I've been buying WDC Red drives.
What are the SMART stats on disk 1? - sridgwayAspirantThanks for the reply, I will buy a WD RED WD20EFRX and see how it goes
What do you mean by the SMART stats, after syc the b=new segate drive reporting as a failed disk, the light flashing on it's bay.
Steph - sridgwayAspirantWell I can confirm it was the segate ST2000DM001. I purchased a new 2 Tb WD RED WD20EFRX and it syn fine and has been working fine since. Time the segate model was taken off the hardware compatibility list I think.
- StephenBGuru - Experienced UserGlad it is working now. SMART+ stats are found on the health tab of frontview. You can google SMART and get some guidance on what the stats are good for.
- sridgwayAspirantthanks for that, I had never clicked that button before I had mainly relied on the logs for information, just goes to show you learn something new every day :>
here are the current stats for the 3 of the 4 drives. Drive 1 is the new drive and 2,3 and 4 are the pre existing segate drives. Disk 4 looks to have some relocated disk errors and I have had a couple of notifications regarding this drive in the past. Over the next month or so I might replace all the remaining drives.
Thanks for your support
SMART Information for Disk 1 (WDC WD20EFRX-68AX9N0 1862 GB)
Model: WDC WD20EFRX-68AX9N0
Serial: WD-WMC300371955
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 4125
Start Stop Count 19
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 59
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 6
Power-Off Retract Count 5
Load Cycle Count 13
Temperature Celsius 29
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 771
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 2 (Seagate ST31000333AS 931 GB)
Model: ST31000333AS
Serial: 9TE0ZBZD
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Start Stop Count 12451
Power On Hours 30070
Spin Retry Count 46
Power Cycle Count 96
End-to-End Error 0
Reported Uncorrect 0
Command Timeout 4
High Fly Writes 62
Airflow Temperature Cel 34
Temperature Celsius 34
Head Flying Hours 125559073954558
Total LBAs Written 1506392878
Total LBAs Read 4220859648
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 26
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 3 (Seagate ST31000333AS 931 GB)
Model: ST31000333AS
Serial: 9TE0QXTK
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Start Stop Count 12462
Power On Hours 30069
Spin Retry Count 86
End-to-End Error 0
Command Timeout 3
High Fly Writes 26
Airflow Temperature Cel 38
Temperature Celsius 38
Head Flying Hours 242407954209551
Total LBAs Written 1543315895
Total LBAs Read 371866688
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 257
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 4 (Seagate ST31000333AS 931 GB)
Model: ST31000333AS
Serial: 9TE0Z8CK
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Start Stop Count 12470
Reallocated Sector Count 40
Spin Retry Count 204
End-to-End Error 0
Command Timeout 4
High Fly Writes 1528
Head Flying Hours 168822279527031
Total LBAs Written 1421001211
Total LBAs Read 732597788
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 2
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0 - StephenBGuru - Experienced UserThe spin retry counts are something to keep an eye on - that is the number of times the disks didn't spin up to the operational speed.
lp stat events are something Netgear added - you have lots of them on disk 1. I'm not sure if that is something that matters or not, though you might keep an eye on how fast they increase.
Reallocated sectors, uncorrectable sectors, and current pending sectors are the big three parameters, and they all are 0.
