canadianken
Nov 25, 2015Aspirant
ReadyNAS NV+ Freezing/Locking up. Diagnostic Help Please!
Hey Guys, My reliable ReadyNAS has been given me issues this last week. It's a ReadyNAS NV+ v1 loaded with 4x2TB WD Green drives. FW is current at 4.1.14. I'm posting here becasue I found thi...
canadianken
Nov 28, 2015Aspirant
Thanks again mdgm.i was able to scan each drive individually and identify errors on one disk. I have removed that disk and verified that the nas boots up and files are accessible, obviously this isn't a fix as it is still in a degraded state. The memory tests checked out ok. Two follow up questions:
1. How could one failing disk like this crippled the nas completely and why wouldn't the nas detect any issues with the drive or give any indication of a problem with a specific disk.
2. Moving forward- should I attempted to repair/ format the problematic drive or am I able to replace that drive with a drive of a different size and have the readynas rebuild the array? Can x-raid rebuild in that situation?
Thanks again
Thanks again
- StephenBNov 28, 2015Guru - Experienced User
1) depends on the failure mode. RAID doesn't guarantee that the system will boot with defective drives.
2) I'd replace the disk with another 2 TB drive (I recommend a WD20EFRX). You can't go smaller (the array won't build) and you can't go larger (since 2 TB is the max for your NAS).
