Jerry2011's avatar
Jerry2011
Readynas NV+ motherboard/case exchange
Hi everybody,
today, my infrant NV+ brought 2006 went up in smoke - the motherboard is burned.
How can I save my data?
Hopefully, the pretty new 3x2TB harddisks in X-RAID configuration with my data are fine.
I have another Netgear NV+ from around 2009, can I simply take the 3 harddisks and put them in the same order in the identical slots from the newer NV+ in order to gain access to my data?
Do I have to make a special configuration or so in the firmware of the new nv+-NAS?
Thanks in advance,
Tom
  • Thanks for your answer!
    a) In the kb-article is written: "Never migrate disks if your volume is in degraded mode. Make sure the volume is redundant first."
    Of course the motherboard burned while the Device was up and running - I don't know if the device was in sleep mode or whatever. So most likely I can not tell if the disks are redundant now or not.
    What should I do and how can I check this?
    b) My SN on the burned device is 58552561347, so I'm in this affected group? I never heard of this problem, so it might be the reason why the device burned.
    I will look for it on the other nv+. Thanks!
    Best regards, Jerry
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    a) You can connect the disks up to an internal SATA port on your PC to check them. If they are fine then the array probably is redundant.
    b.) Sounds like it's the PSU that's gone up in smoke. What region are you in (e.g. US). You could contact NetGear referring to the service action and see if they will issue a replacement PSU. Post your case/RMA number (whichever you get) preferably in the thread title (i.e. subject of first post in the thread).
    Also take a look at this: http://www.readynas.com/kb/faq/hardware/how_do_i_replace_the_stock_power_supply_on_the_readynas_nv
    If you remove the PSU you should be able to confirm it's the problem.
  • I'm located in Germany.
    So if the PSU is burned, don't you think that the rest of the board is also affected?
    Normally, if a PC is burned, because of high voltage peaks, a lot of other components are also touched.
  • what should I do if the harddisks are NOT redundant?
    Then the only way is to get the burned device going again?
    mdgm-ntgr
    A number of users have had failed PSUs and after replacing them the NAS has been fine again (edit: should note that this may not necessarily always be the case, but usually is).
    The RAID array can most likely be moved to another NV+ v1 unit. If your backup is not up to date and your data is important then you should consider cloning the disks just in case something goes wrong with the migration.
ProSupport for Business
