jfb1
Nov 16, 2016Aspirant
ReadyNAS NV+ needs new power supply
Hello! Like many other posts here, I've experienced a power supply failure on my ReadyNAS NV+ RND4000v1. I understand these devices are end of life, but I would like to see if I can get a power supp...
jfb1
Hello vandermerwe,
Yes, I was hoping to get a new power supply in order to get the ReadyNAS NV+ running again ASAP as I need access to that data for time critical assignments. I would then start a plan to migrate off the device onto a new device. I understand it's simply not a "swap disks" kind of thing. There is a LOT of data I would have to move to whatever temporary location I can come up with and that will take time as well. Is there a way I can get a PSU replacement?
bedlam1
Nov 16, 2016Prodigy
Not sure where you are located jfb1 but you may find this link helpful http://www.evercase.co.uk/CompatibilityListReadynas.htm
as well as this one http://www.downloads.netgear.com/files/GDC/READYNAS-COMMON/Replacing%20the%20PSU.pdf
- bedlam1Nov 16, 2016Prodigy
or a better price here http://www.ebay.co.uk
Both linked companies here and in post above ship worldwide
- jfb1Nov 16, 2016Aspirant
Thanks bedlam1!
I'm in the US. Yes, I can find a PSU replacement but they are pricey. My understanding was that Netgear was honoring warranties because of faulty PSUs on the Netgear NV+. At least that is what I picked up from other posts here. I don't want to shell out a couple of hundred dollars on a PSU for a device that is end-of-life if I don't have to. But perhaps I will have no choice.Thanks again,
JFB
The replacements were only for a limited range of Serial No.'s if I remember correctly
Supply and shipping from UK would be about $100
Thanks bedlam1.
Do you happen to have the link to the affected serial #s? I cannot seem to locate on Netgear site. I'll keep searching. Thanks for the additional info on replacement PSU.
JFB
