monkeyass
Apr 15, 2016Aspirant
Readynas NV+ SLOW TRANSFER
Hi
Recently picked up a ReadyNas NV+. I have a Sky Hub as my main router which connects to a Netgear GS208 and all my ethernet connects go to this. When trying to transfer files from my Laptop to my Readynas via ethernet im only getting speeds of 1.2mb. Ive tried turning off antivirus. Ive enabled and disable jumbo frames. Scoured the internet for ideas but still coming up stumped
What firmware is on the NV+?
Did you look for SMART errors on the disks and also packet errors on the NIC card?
- JennCNETGEAR Employee Retired
Hello monkeyass,
Is your laptop transferring files to the NAS via wireless? Please see if you get the same problem when you are connected via LAN cable to the same network where the NAS is. It is possible that if that is wireless, the slow connection has something to do with wireless signal.
Welcome to the community!
Hello monkeyass,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!Regards,- monkeyassAspirant
Hi
Ive turned off the wifi connection so its definately transfering via ethernet.
Firmware is RAIDiator 4.1.14
How do I check for SMART errors? Complete newbie at this NAS stuff.
- Jan 21, 2017Retired_Member
