mattson
Sep 14, 2016Aspirant
Readynas NV+ v2 XRAID2 does not utilise extra capacity on 4TB disks
Hi there,
I recently had 2 failed drives in my trusty Readynas NV+ v2 - 5.3.12 firmware - so decided to try my hand with 4tb drives, the only ones supported for the NV+ v2 were the WD Reds (can't remember hardware number off the top of my head, but I got the exact one listed in the compatibility chart.
since I had an external backup of the content - I figured I'd factory reset the box and let it recreate the volume again from scratch... this went as planned and I let it create the volume as X-Raid 2, now I had previously used 2 different x-raid calculators and they'd both told me that it would give me approx 7.2tb of storage... however, once completed, I only got 5.4tb (which was basically the same as what I had with the 4x 2tb drives... figuring I had done something wrong, or the previous configuration was still in effect, I took all the drives out, ran a diskpart - clean - on all 4 drives and tried again, with configuration being 2x 4tb drives in channel 1 & 2, with 2x 2tb drives in channel 3 & 4. however, the same outcome resulted from this step as well... a 5.4tb volume clearly showing x-raid.
so - are the calculators wrong? or is something else a-foot?
what am I missing?
Cheers,
Matt
mattson wrote:
Thanks for the reply mate.
I left it overnight, and it finished it's initial sync, but when that completed, it just remained at 5.4tb.
kinda frustrating :(
Reboot it.
- mdgm-ntgrNETGEAR Employee Retired
There will be an initial sync using the capacity of the smallest disk and once that completes if you have more than one 4TB disk installed it will then proceed to create a second layer, do a resync and expand onto that.
- mattsonAspirant
