Yeahh's avatar
Yeahh
Readynas NV+ ver 1 equivalent ?
I currently have an NV+ ver 1 which has just died on me. So I have two needs. 1). What would be the new equivalent model? 2). How do I get my data from the old unit to the new one? I was hoping I could just drop the drives into a new model but apparently that won't work. The old unit has 3 1TB drives that were running in an xraid configuration.
The primary use for the readynas is just a home storage system. Photos, movies, iTunes music etc. Have both a PC and Mac environment.
Thanks in advance!
  • StephenB's avatar
    In the new line, the equivalent model would be the RN104. The RN314, RN514 are higher performance business versions.
    You could also consider a Pro-4, as they are being discounted as they roll over to the new line. It would have a 5 year warranty, much higher performance than your NV+, and a similar GUI.
    Either way, you can't migrate your disks. There is a post here that gives you some options, but it assumes a fair amount of facility with linux: http://home.bott.ca/webserver/?p=306.
    Do you have a backup?
  • No, unfortunately I don't have a backup...my readynas pretty much acts as my backup.
    I'll take a look at the options you mentioned. I'm fairly technical but have zero experience with Linux.
    I'm trying to find a used NV+ for sale that I could swap into but that is proving difficult.
  • I have no idea when this model was bought. I got it in a trade for some other equipment. Interestingly enough on the back of the unit it does not have a serial number.
    I think for my fairly basic needs the 104 looks like it will get the job done. The 314 would obviously be better, but im not sure it's worth the extra $$ for my needs.
    My main issue now, is how to transfer my HD's or data off the old unit into a new one.
  • It likely already had a PSU swap then. The serial number sticker was on the PSU portion.
ProSupport for Business
