wysiwyg31
Dec 05, 2019Tutor
Readynas OS6 : rsync over SSH won't work (log say rsyncd.conf missing, but it's there...??)
Hi ! I try to backup a synology nas on a readynas OS6 with rsync & ssh. Currently both nas are on same LAN. Rsync without SSH works (synology find my readynas rsync shares and backup perfectly)...
Marc_V
Dec 09, 2019NETGEAR Employee Retired
RYSNC over SSH shouldn't need to have rsyncd.conf to run. Have you checked the syntax you entered?
Regards
Dec 10, 2019Guru - Experienced User
You might also try running an rsync-over-ssh backup job on the ReadyNAS, instead of running it on the Synology.
