wysiwyg31
Dec 05, 2019Tutor
Readynas OS6 : rsync over SSH won't work (log say rsyncd.conf missing, but it's there...??)
Hi ! I try to backup a synology nas on a readynas OS6 with rsync & ssh. Currently both nas are on same LAN. Rsync without SSH works (synology find my readynas rsync shares and backup perfectly)...
Dec 10, 2019Guru - Experienced User
wysiwyg31 wrote:
Do you mean that instead of having the synology as "master" (triggering and managing the backups, uploading data to readynas), I could try the other way around, with the Readynas managing the backup and downloading data from opened shares on the Synology ?
I could give a try, but for now, the synology is my "main" nas (the readynas is a bit old), so I would have prefered to manage everything from the syno.
Yes.
I think it's worth trying at least as a test.
FWIW, one benefit of running the backup job on the ReadyNAS is that you can then put the ReadyNAS on a power schedule. I run my own backups on the ReadyNAS destination machines for that reason.
wysiwyg31
Dec 10, 2019Tutor
Yes, I had this in mind when reading your proposal.
I already had a look on how to remotely power off the readynas, it seems possible, but I guess much easier that it power off itself after finishing the job.
