Blues11
Mar 16, 2017Luminary
ReadyNAS Pro Business Edition Hard Drive
I'm looking for the compatibility list for hard drives, specifically for legacy products. I have a hard drive in a Business Pro that's had increasing reallocated sector counts. Does the compatibility...
coloatty
I have a legacy ReadyNAS Ultra 6 Plus, which boots up and shows the model as "ReadyNAS Pro." Since its release, I have been using OS 6.6.1 (Plex app only and antivirus off) without any issues. Certain apps and Antivirus on seem to have been a problem for others.
The HCL for legacy products appears to be updated no longer. In addition to what is shown on the dormant HCL, I have successfully used HGST 8TB (HUH728080ALE600) and just started using 10TB (HUH721010ALE600) drives in the Ultra 6 Plus/"Pro."
coloatty
ReadyNAS Hard Disk Compatability List:
http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List?cid=wmt_netgear_organic
Choose "Legacy" at bottom of dropdown list, then select device from additional dropdown list.
- Blues11Mar 17, 2017Luminary
Thank you for the informationand for the link. I feel fortunate that the old Business Pro (or is it Pro Business?) seems to be working well. It doesn't get much use, but it's nice to know it's there should there be the need.
Thanks again.
- mdgm-ntgrMar 17, 2017NETGEAR Employee Retired
Note that users have reported success with some disks not on the compatibility list for the Pro BE especially on OS6. YMMV.
- ERAJJun 17, 2017Aspirant
I've tried on three different computers and the link for compatability list has the "This content cannot be displayed in a frame" in IE and Firefox, and nothing in Chrome. How do i get to the list?
THanks.
