mervincm
Jul 01, 2013Aspirant
ReadyNAS RN104 ESATA+USB
Having some difficulty finding use for these port, so I have some questions ReadyNAS 104 with 4x1TB Seagate 7200 in (RAID 5) XRAID 6.0.8 -Does it support Hot swap on the ESATA, or must you add i...
evan2
Jul 02, 2013NETGEAR Expert
Which eSATA model do you use? You had better reject eSATA driver firstly on UI, then unplug eSATA.
For USB3.0, You also had better reject USB driver firstly on UI.
