mervincm
Jul 01, 2013Aspirant
ReadyNAS RN104 ESATA+USB
Having some difficulty finding use for these port, so I have some questions ReadyNAS 104 with 4x1TB Seagate 7200 in (RAID 5) XRAID 6.0.8 -Does it support Hot swap on the ESATA, or must you add i...
mervincm
Jul 02, 2013Aspirant
evan wrote: Which eSATA model do you use? You had better reject eSATA driver firstly on UI, then unplug eSATA.
For USB3.0, You also had better reject USB driver firstly on UI.
I have a RN104
http://www.netgear.com/landing/storage/for_home.html#tabs
It lists eSATA expansion port
If you were asking about my external Esata enclosure, I tried a couple including a
4 disk ESATA enclosure (to test it if supported a port multiplier on ESATA) (was not sure how to tell if it worked)
2.5" seagate freeagent goflex ESATA (no ESATA power)
I appreciate your attempt to respond, but I do not understand what you are suggesting. It appears you are listing what I should do to safely remove a working shared external drive. I should "Eject" the "drive" in the UI then unplug the external device.
I am not having problems disconnecting working drives, I am asking questions about what to expect when I hookup new external drives via USB and via ESATA.
