mervincm
Jul 01, 2013Aspirant
ReadyNAS RN104 ESATA+USB
Having some difficulty finding use for these port, so I have some questions ReadyNAS 104 with 4x1TB Seagate 7200 in (RAID 5) XRAID 6.0.8 -Does it support Hot swap on the ESATA, or must you add i...
mervincm
Jul 03, 2013Aspirant
Thanks for your reply. I typed in a large update yesterday, but my session timed out and it was lost before post.
Using a standard, single disk, vantec NX3 enclose and linux or MBT/NTFS disk I was indeed able to verify that this model does indeed support HOT-ADD of eSATA Disk and USB2 Disk they are auto mounted.
I saw no support on USB3 with my Seagate 1TB freeagent goflex using its swappable USB3 interface. I can confirm it did work on the front USB2 connector
