sventunus
Feb 26, 2013Aspirant
ReadyNAS Ultra 6 rattling
Dear Netgear, I have been owning a ReadyNAS Ultra 6 for about 2 years, and since a couple of weeks the device is making a rattling sound all the time. I removed the side panels from the case to ch...
kossboss
Feb 26, 2013Guide
If 1 drive fails replace it immediately - you can hot swap it or swap it with a shutdown
Check logs frequently - for ATA Errors: 1 and over - Reallocated Sectors: 50 and over - thats when we replace drives (if you purchased the NAS with drives, call us when you see errors like that and we will replace the disks) If you purchased disks seperately please call drive manufacturer.
