sventunus
Feb 26, 2013Aspirant
ReadyNAS Ultra 6 rattling
Dear Netgear, I have been owning a ReadyNAS Ultra 6 for about 2 years, and since a couple of weeks the device is making a rattling sound all the time. I removed the side panels from the case to ch...
sventunus
Hey Stephen,
I have USB HDD docking stations laying around & can test disks using testdisk by CG Security under Linux, so no problem there.
I don't suspect any problems with the drives however. I assume it's the disk mounting or the chassis fans that are causing the rattle, but we'll know for sure this weekend.
Thanks once again for the tips!
Extremely logical & simple, if you think of it that is ;-)
