sventunus
Feb 26, 2013Aspirant
ReadyNAS Ultra 6 rattling
Dear Netgear, I have been owning a ReadyNAS Ultra 6 for about 2 years, and since a couple of weeks the device is making a rattling sound all the time. I removed the side panels from the case to ch...
Mar 03, 2013Guru - Experienced User
I'd start a support request at support.netgear.com I'm not sure if they will offer to send you a PSU or RMA the unit. In the latter case they can ship it in advance of the return (so there is no downtime).
They can probably also answer the do-it-yourself question, though it might void the warranty.
