kcrossley
Aug 30, 2012Aspirant
ReadyNAS Ultra vs NV+?
I have an opportunity to upgrade from a ReadyNAS NV+ to a ReadyNAS Ultra. In terms of performance, is there a significant difference between the two? What other benefits does the Ultra offer? BTW, ...
PapaBear1
Aug 30, 2012Apprentice
If your NV+ is more than a year old it is most likely a v1. If it has a silver colored case, it definitely is a v1 and in addition the v2 is black has a power brick as opposed to an internal power supply.
The difference will be night and day, with the file transfer speed in excess of 2x as fast, and closer to 3x. However, if your NV+ is still functional, I would recommend that you put new drives in the Ultra and then transfer the files over via the network. Then you can set the NV+ up to serve as a back up unit to the Ultra. I did that when I got my first NVX.
