lefjomp's avatar
lefjomp
readynas ultra4 problem, booting checking fs
hi!
today could no longer access my shares in my computer, it said something like that the path was no longer existing, but i was able to log in as admin and i entered the volume section and it says dead, i couldnt see any of my drives, i have 3 pcs 2 tb drives, and there all in the compatiblity list.
after that i restarted the ultra and now i have a different ip number in raidar and it says checking fs.
its been like this for 15-20 minutes now, how long should this thake?
and what have happened?`
i have all my photos and videos of our entire life on that "safe" nas.
i really need help!!
  • I would most definitely recommend opening a ticket with support to resolve this issue, please do not attempt to correct this on your own. If you have owned the NAS for more than 90 days, use online support http://www.readynas.com/support
    You can always skip the volume check via the boot menu to see if you still have access.
  • i managed to get the nas to work again, but there is something wrong, i was able to get in to the nas as admin and i managed to use the shares in my laptop and the volume seemed ok again after a reboot and during the night it resynced all the data, but now in the morning the volume is dead again, but i can access the shares through my computer.
    is this a harware problem with the nas?
    or is this a problem with some of the disks?
    or is it a software failjure?
  • should i try to remove a disk at the time and see if the problem is still there?
  • the entire volume is marked as dead, but i can still access the shares through my computer, and i can still download files using transmission.
    any suggestions?
ProSupport for Business
