rusaldeev
Jan 27, 2016Aspirant
ReadyNASRND4000 NV+ compatible 220V power unit
Hello,
after almost 6.5 years of flawless operation my NV+ just died, looks like power supply was burned, I was actually repositioning my NAS without powering it off,
Question is: what is the exact model of power supply unit of my NAS, I need to order it ASAP and replace.
Here is some info about my NAS below:
Product Model : ReadyNASRND4000
Serial Number : 1S978CRE00503
Purchase Date : 09-Sep-2009
thanks!
Hello rusaldeev,
Welcome to the community!
RND4PSU1-10000S is the exact model for the PSU of ReadyNAS NV+v1.
- JennCNETGEAR Employee Retired
Hello rusaldeev,
- rusaldeevAspirant
thanks!
So if I just buy this one, will that fit and work fine?
It should, though it is regrettably overpriced. If you have a data backup, you might consider replacing the NAS instead.
You could also look into an overseas supplier - even with shipping costs, it might be quite a bit cheaper.
http://www.evercase.co.uk/CompatibilityListReadynas.htm
http://www.hamiltone.co.uk/menupage.html also claims to have some, though you'd need to email them to get pricing.
