Magmo
Mar 03, 2014Aspirant
replace with different hard drive
Hi
One of my disks have failed and need to be replaced, I can replace with a compatible hard drive with equal or greater disk capacity without any issues right?
- vandermerweMasterDid you use the hitachi drive fitness test tool?
http://www.hgst.com/support/downloads
You'll need to remove the drive withe Nas off and connect it to a PC. - MagmoAspirantYes I used that tool and disconnected all drives and checked each of them on my pc
- vandermerweMasterOk then.
Use the existing drives then.
Make sure you have a backup.
