monodead
Mar 08, 2013Aspirant
resetting readynas nv+
hi i have a issue with resetting my readynas . i have followed the instructions about ressetting nv+. it stops every time with the message . tftp arp error . what can be the problem ? the reason ...
monodead
Mar 11, 2013Aspirant
hi thanks .
im using RAIDar version 4.1.7 on my mac .
instructions are .Power off your unit.
Using a straightened paper clip, press and hold the Reset button.
Press the Power button to power on the unit.
Continue to press the Reset button until the status display screen shows an boot menu message.
Press the Backup button to scroll through the boot mode options.
Press and release Reset button to confirm your boot menu selection.
best regards fredrik
