monodead
Mar 08, 2013Aspirant
resetting readynas nv+
hi i have a issue with resetting my readynas . i have followed the instructions about ressetting nv+. it stops every time with the message . tftp arp error . what can be the problem ? the reason ...
Mar 15, 2013Guru - Experienced User
Perhaps the OS partition is too full. Try doing an OS reinstall (which will preserve your data and most settings, but will reset the admin password and also configure the IP settings to DHCP).
