bobfa100
Apr 12, 2017Aspirant
Restoring a RN102 After Factory Reset
RN102 FW 6.7 RAID1 with two 4 TB drives I had to factory reset my RN102. That went fine. Now I have 4TB of clean space. Prior to the reset, the RN102 was backed up to an external 5TB driv...
- Apr 18, 2017
Hello bobfa100,
You are most welcome! If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JennC
Apr 13, 2017NETGEAR Employee Retired
Hello bobfa100,
Please check this article: How do I back up data from a USB disk to my ReadyNAS OS 6 system?
- bobfa100Apr 13, 2017Aspirant
Thanks JennC
- JennCApr 18, 2017NETGEAR Employee Retired
Hello bobfa100,
