NetworkMechanic
Oct 20, 2015Aspirant
RN 104 freezing/not responding/locking up with FW 6.4.0
RN 104 keeps freezing and becomes unresponsive (even the lcd screen freezes). I have to disconnect the power supply everytime. It tries to resync the data, but it freezes at random points. 3x 1 TB ...
BrianL2
Nov 07, 2015NETGEAR Employee Retired
Hi coxo01,
Have you tried the ReadyNASOS 6.4.1-T29 (Beta 2)?
Kind regards,
BrianL
NETGEAR Community Team
coxo01
Nov 08, 2015Aspirant
Froze as soon as i attempted to copy over a 1.5GB MKV File. (on beta 2)
- BrianL2Nov 08, 2015NETGEAR Employee Retired
Hi coxo01,
If you have contacted support before, I suggest you continue your support case with them to further investigate this issue.
Kind regards,
BrianL
NETGEAR Community Team - coxo01Nov 08, 2015Aspirant
Hi Brian,
Tried something different now and have not had any problems so far.
I was connecting and transferring files via AFP, switched over to SMB and seems stable for now.
Copied over a few files so far and no crashes (using Beta 2).
Will keep you posted.
Thanks,
coxo01
- atreyu_ATRNov 09, 2015Aspirant
I am having the same lock up problem that everyone else seems to be having since upgrading to 6.4.0. To make my box stable I disabled the transmission and usenet clients.
Unfortunately, I don't have the space to copy everything off my nas to downgrade it.
I have since upgraded my firwmware to 6.4.1-T29, and all was going well with transmission running for a few hours however after about 30 minutes of SABNZB running my RN104 froze up again. I've emailed my logs in.
Please help!
- RobTWoNov 09, 2015Guide
Wouldn't it be easier for Netgear to renumber 6.2.5 to e.g. 6.4.2 and then publish that version as new update? That would solve a lot of problems.
- StephenBNov 09, 2015Guru - Experienced User
Clearly not, given the pain you need to go through to downgrade. It's not about changing the numbering.
What's needed is to fix the problems. I'm seeing a bit of a shift - more new problems being posted seem to be with third-pary apps - particularly transmission.
In any event, I have seen improvements in 6.4.1 beta (though there still is a way to go).
Any help for me StephenB?
I am thinking you should disable SABNZB and transmission for now, and see if the lockups stop. If they do, then try enabling them one at a time, and see if you can isolate the problem to one of those two apps.
I have since upgraded to 6.4.1-T29 in the hope for more stability. When trasmission and SABNZB aren't running it seems to be stable. Last night i left it running with just transmission and it appeared to be stable, however when I woke up this morning, it had locked up. When im running SABNZB it can lock up within 30 minutes. It appears to be either.
Are there any newer beta's that I can try? or anything new on the horizon?
- jsmcNov 15, 2015Aspirant
Hi! Readynas 102, 2x 3 tb. WD RED, firmware 6.4.0 here,
I can transfer files and use the NAS normally, my issues comes with the shutdown program, if transmission app is enable and downloading when the time for shutdown comes the unit turns off hard drives, but doesn't shutdown itself and the power led stays blinking until i pull the power plug, but if the app is running and there are no downloads active the unit turn off OK. This it's not related to 6.4 i'm not sure since when, but could be 2 or 3 versions before, disk spin down is disable and my logs don't show anything related.
