NetworkMechanic
Oct 20, 2015Aspirant
RN 104 freezing/not responding/locking up with FW 6.4.0
RN 104 keeps freezing and becomes unresponsive (even the lcd screen freezes). I have to disconnect the power supply everytime. It tries to resync the data, but it freezes at random points. 3x 1 TB ...
NetworkMechanic
Dec 08, 2015Aspirant
Anyone still having problems even with the new update 6.4.1?
I am. I don't know what to do. It's so unreliable. I'm afraid to keep storing my photos on there.
- atreyu_ATRDec 08, 2015Aspirant
Ive been going through tech support. and what they told me was the problem was related to NODE SIZE issue. The problem stems from my RAID been created back with an old firmware version 6.1.5.
According to them the only way to fix it was to wipe the entire volume and recreate it with the latest firmware. I've just finished doing that and im currently copying everything back on my NAS. And I have had any lock ups since.
- StephenBDec 09, 2015Guru - Experienced User
Interesting, thanks for sharing.
Netgear did recommend a factory reset back then to get best performance. But it was a suggestion - obviously they didn't expect lockups later on.
If you don't have a backup, I'd suggest trying to make one.
A factory reset is one thing to try, there is evidence from a couple of posters that it can help. Someone just posted that they had a RAID volume created back on 6.1.5 firmware, and that a factory reset solved it (Netgear did make some adjustments to their BTRFS filesystem configuration back then).
- atreyu_ATRDec 09, 2015Aspirant
Tech support believed the problem was due to the 'node size'. and the factory reset would fix this. I've messaged them back and asked them to confirm that now i have formated that the 'node size' issue is now fixed. They have asked me to send logs (which I just did)
- azervaJan 03, 2016Tutor
Hi everyone,
I'm having very similar issues on my RN 104 using 6.4.1. I have no addons running on my box. I get complete freezes with no option but to pull the plug. After reboot, the entire volume resyncs. This is a very serious issue in my mind, as resyncs put a lot of strain on the disks, and having this happen every few days basically means the drives are running 24/7.
I don't know about everybody here, but having Netgear asking us to just have another 8 TB lying around in disk space to be able to perform a factory reset is an outrage to me. Has anyone had any other solutions for fixing this other than wiping the entire volume?
