NetworkMechanic
Oct 20, 2015Aspirant
RN 104 freezing/not responding/locking up with FW 6.4.0
RN 104 keeps freezing and becomes unresponsive (even the lcd screen freezes). I have to disconnect the power supply everytime. It tries to resync the data, but it freezes at random points. 3x 1 TB ...
atreyu_ATR
Jan 08, 2016Aspirant
Yes since I did my factory reset, I asked their tech support to remote back in and confirm that the node size issue was resolved. They said it had. I haven't had a lock up since.
Make sure you upgrade to the latest firmware THEN do the factory reset.
kroche
Jan 15, 2016Aspirant
Latest update:
I have now installed the very latest beta software, done the factory reset and I am now copying data back to the readyNAS. Seems to be stable so far with no drop outs. It might be a bit slow but at least it works. It will take a few days to complete the restore as I'm doing it a bit at a time and checking each step.
Kevin
