NetworkMechanic
Oct 20, 2015Aspirant
RN 104 freezing/not responding/locking up with FW 6.4.0
RN 104 keeps freezing and becomes unresponsive (even the lcd screen freezes). I have to disconnect the power supply everytime. It tries to resync the data, but it freezes at random points. 3x 1 TB ...
NetworkMechanic
Jan 26, 2016Aspirant
Anyone have any success?
Mine freezes when I attempt a time machine back up.
Anyone have that problem?
I'm running the latest firmware.
- ChristopheDJan 26, 2016Aspirant
I certainly have this problem. Systematically, when I run a back up job (on the front USB), the NAS freezes.
I run 6.4.0 as 6.4.1 simply slowed down the unit to a virtual halt.
Yet all the other parameters seem to be ok....
In 6.2.5, my back up jobs were running like a charm.
I think the OS is simply not up to par and it does not seem that Netgear has an intent to fix. These problems have been dragging on for a long time now.
I am at a loss. With a non-negligible number of users, I think we'll have to move to a more robuts hardware/software combination. This level of performance is simply not acceptable.
- krocheJan 26, 2016Aspirant
My steps to cure the problem of the freeze is to do a factory reset which will lose all the current data so you need to backup first. My RN 104 has worked perfectly since I did that. I also stopped running the Virus scanner, but I'm not sure that makes any difference.
The current OS version is simply incompatible with the way the disk was formated by the earlier version.
Kevin
