jkucukov
May 02, 2018Aspirant
RN2120 Hot Swap HDD by Accident now Re-syncing
Hi, new to the community, looking for wisdom :)
I've got a RN 2120 with 4 x 4TB WD Black drives, the NAS is setup as RAID5 for home use storage, total space comes out to 10.9TB.
The hard driv...
- May 03, 2018
What firmware is your system running?
jkucukov wrote:
is this normal under RAID5?
If somebody could explain, why would the empty hard drive need to be re-synced for RAID5 if there’s no data?
It is normal. RAID5 creates a virtual disk, and the NAS puts a file system onto that virtual disk.
The RAID structures (parity blocks etc) therefore operate on the raw disk sectors. It doesn't matter if those sectors are used by the file system or not - the RAID software neither knows that or cares about that. When you reinsert a disk, the array needs to be resynced. It takes the same time when the disks are full as it does when they are empty.
That said, with OS 6 there usually is some user action required when you insert a used disk in the NAS. That is why I am wondering about what firmware you are running (and if it is up to date).
May 03, 2018Guru - Experienced User
jkucukov
May 03, 2018Aspirant
Thanks for the reply, I was wondering if it had any intelligence to know what was set up once before.
The RN2120 has the latest 6.9.3 version.
Funny that there are no labels or warning on these devices letting a user know in case you decide to take out a hard drive by accident plan for a complete re-sync. It was frustrating, I thought I broke something :)
- StephenBMay 03, 2018Guru - Experienced User
There is some information on the drives, including transaction counts that can be used to tell how far out of sync the drives are.
I don't know how Netgear uses that info; though IMO it is generally better to do a potentially unneeded resync than to risk a corrupt file system.
