arun-india's avatar
arun-india
RN426E22 NAS Stuck on "Welcome to Netgear Storage" – No Button Response, No Network Access
Hi Team,
My NAS (model: RN426E22) is stuck on the "Welcome to Netgear Storage" screen.
There is no response when I press the center button or any of the four surrounding buttons. Additionally, the device does not appear on the network — the assigned IP address is not reachable/pingable.
  • Replaced RAM & Working Fine
    I removed the RAM stick and powered it on — it still stopped at the same “Welcome” screen. Then I replaced the RAM with another one, and this time it showed “Booting...”. After that, I inserted the disks and powered it on again, and now it’s working fine. Thank you very much for your inputs Sandshark​ & StephenB​
    I’m planning to collect all technical details to ensure I can rebuild the shares from a Linux PC if the NAS fails again in the future. Could you please advise what information I need to note and where to find it?
    Also, since this product is no longer supported, my company management is ready to procure another rack-mountable NAS. Could you experts please suggest a reliable, rock-solid make and model?
  • I've not confirmed this,. but I suspect that Welcome to Netgear Storage is the default programmed into the display panel on OS6 units just as simply ReadyNAS is programmed into it on older units.  That means that a whole lot of things can be wrong and result in that display because it doesn't even have to complete POST.  Can you get into the reset button menu (see How-do-I-access-the-boot-menu-on-my-ReadyNAS-526X-and-626X)?  Does it display anything different when booted without drives? (Remove and re-install them with power off and mark the slot that came from, so you can re-install them in the same order.)
    The usual first suspect is the power supply.  The 426 is getting to be old enough that that could be your problem.   But it's a bit early to jump to that conclusion.
    • arun-india's avatar
      arun-india
      Hi Sandshark​ , Thanks for your response.
       If I am doing in following order, will it affect the data or existing RAID settings ?
      1. Switching off the device & removing power cord too
      2. Marking some mark in disk to identify the positions ( 6 disks are there ) & removing all disks.
      3. Just switch on and observe ( hope this you mean by ->  Does it display anything different when booted without drives?)
      4. Switching Off again,
      5. Powering on the NAS with press and hold the Reset button. to do the 'memory test' in boot menu
      6. After that power off again and inserting all disks in previous positions then switching it on
      I want to try reinstall OS  ( hope that also will not affect the existing data) . can you please share that steps too
      • StephenB's avatar
        They are in the hardware manual - see pages 105-106:
        The OS reinstall is data-safe, but does change a couple of settings:
        • The admin password is reset to password
        • The network configuration is changed to DHCP with no bonding
        • Volume quota is disabled (it can be re-enabled from the volume settings wheel).
        That said, it is unlikely to solve your problem.  Testing the disks in a PC could rule out a disk-related issue - start with disk 1, as the NAS will boot from that disk slot if it is installed.
        The instructions also include running the memory test.
        FWIW, I agree with Sandshark​ that a failed power supply is the most likely cause.
        It normally will display a "no disks" status.
ProSupport for Business
