Oz_Pete's avatar
Oz_Pete
RND4000 trying to boot from USB but OS Index Error
Hi Team,
I have an RND4000 NV+ 4  Bay. It is stuck on boot, I have done the initialisation of OS already, still the same. I have downloaded both the oldest and newest radiator bios firmware files from the support page. Loaded them one at a time on a blank FAT32 format USB in the root directory, then placed the USB in the front USB socket on the NAS unit. Held the power but down for 20 secs until the display indicated USB boot mode. In both instances the sequence stopped with an error "BIOS INFO: OS Index ERROR". This would happen with or without disks being in.
I cant find any reference to the error.
RAIDar cant see the unit.
Any suggestions would be helpful, the disks have data on them.
Pete
  • StephenB's avatar
    Does your NAS say ReadyNAS NV+ on the front panel?
    Or does it say ReadyNAS NV+ v2 on the front panel?
    • Sandshark's avatar
      Sandshark
      Sensei
      That's not how you create a USB recovery drive.  But how you do it depends on which version of the NV+ you have, which is the reason for StephenB 's question.
    • Oz_Pete's avatar
      Oz_Pete
      Thx Stephen for the response. It has NV+ on the front grille.
      • StephenB's avatar
        There is some risk when running the USB recovery, so it would be good to make sure it is the right step first.
        I suggest powering down and removing the disks in the NAS (labeling by slot).  Then power up.  Normally you would then see a "no disks" message on the LCD screen of the NAS.  Are you seeing that?
        If you are, then I suggest powering down again, and reinserting the disks.  Then power up.  Let us know what is on the LCD screen (if anything).  Also install RAIDar, and see if it can find your NAS.  If it can, let us know what status it is showing (posting a screenshot is a good way to do that).
  • Stephen, just letting you know I am trying to get my hands on a spare drive. I appreciate your help and as soon as I get one I'll be straight back to you.
    • Oz_Pete's avatar
      Oz_Pete
      I have a spare drive now -  its a Seagate Barracuda 160GB. I'll remove the data drives and number them. I will place the spare drive in a caddy and await instructions.
      Many thanks in advance - Pete
      • StephenB's avatar
        Just put the drive into slot 1, and then boot up the NAS and do a factory default.  This normally will do a fresh factory install on the NAS.  If that works (and the system boots normally), then the boot issue is actually due to something on the operational disks, and not the flash memory.
        If you don't recall the factory default procedure, see pages 23-24 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
        Note if the disk is unformatted, then the system will automatically do the install on power up (no need to use the boot menu in that case).
ProSupport for Business
