doublem70
Dec 02, 2012Aspirant
RND4000 v3 HD replace
Hello i'm an Italian lucky owner of a RND4000 v3 ReadyNAS® NV+ with RAIDiator 4.1.10 firmware, equipped with no. 4 HD Western Digital WD20EARS-60MVWB0 2Tb Hard Disk.
My system now is working perfectly and I'd like to know when an hard disk will doesn't work and i will need to replace it how to fix the problem.
The disks i have now are not easy to find because are old model... can I replace only one disk with another model (evenctually from the same manufacturer) with the same capacity or changing model I have to replace a couple or all disks?
Is 2Tb the maximum capacity that my device support? (in the compatibility list miss RND4000 v3).
Please help me
Thanks for Your support
Maurizio
Please help me
Maurizio
- mdgm-ntgrNETGEAR Employee RetiredYou have a NV+ (v1). Any 2TB disk on the compatibility would be a suitable replacement. Yes 2TB drives are the max supported on your model.
Welcome to the forum! - doublem70Aspirant
mdgm wrote: You have a NV+ (v1). Any 2TB disk on the compatibility would be a suitable replacement. Yes 2TB drives are the max supported on your model.
Thanks for Your support...
Now i'm not worried anymore :)
Do You know if is there any system to improve the network performances?
Thanks again
Maurizio
