miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
mdgm-ntgr
May 22, 2015NETGEAR Employee Retired
Using USB may be hit or miss. It may/may not work. Whereas using internal SATA connectors you should be confident that good disks should be detected properly.
