miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
BaJohn
May 23, 2015Virtuoso
Not quite clear where the problem lies here. Is it that USB contacts wear, or some USB's do not have all the connections or what?
mdgm wrote: Using USB may be hit or miss. It may/may not work. Whereas using internal SATA connectors you should be confident that good disks should be detected properly.
The ReadyNAS has a USB connection for backup of the NAS box. Are you saying that for the USB on the NAS box "It may/may not work." as well? :?
