miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
May 23, 2015Guru - Experienced User
I think mdgm's comment is specific to diagnostics.
BaJohn wrote: Not quite clear where the problem lies here. Is it that USB contacts wear, or some USB's do not have all the connections or what?
mdgm wrote: Using USB may be hit or miss. It may/may not work. Whereas using internal SATA connectors you should be confident that good disks should be detected properly.
The ReadyNAS has a USB connection for backup of the NAS box. Are you saying that for the USB on the NAS box "It may/may not work." as well? :?
Sometimes the USB controller in the enclosure will confuse the diagnostic, and it might not properly identify the drive model. Also, some functions (particularly the ATA erase command) won't work (as it usually is limited to SATA). Even in those cases you should be able to run most tests.
I haven't downloaded Seatools in a while, so I can't confirm the OP's report that the newest version is less reliable over USB than the older ones.
An alternative to a USB enclosure is to install an eSata card in the PC. You still need to provide drive power (which you can get via a USB adapter kit like Sabrent's). SATA to eSATA cables are readily available.
