miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
mdgm-ntgr
May 23, 2015NETGEAR Employee Retired
eSATA would be better than USB ,but still internal SATA ports in the PC would be the most likely method to work.
