miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
May 23, 2015Guru - Experienced User
eSATA is completely identical with SATA, it just uses a different connector.
