miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
mdgm-ntgr
May 24, 2015NETGEAR Employee Retired
With eSATA you may use an external enclosure which may introduce compatibility problems. An internal SATA port is the best way to go.
