miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
May 25, 2015Guru - Experienced User
Cracking the PC chassis is certainly not the best option for everyone - and in some cases is not possible. In my case the eSATA is in a laptop.
mdgm wrote: With eSATA you may use an external enclosure which may introduce compatibility problems. An internal SATA port is the best way to go.
Personally I don't use an enclosure with eSATA for drive diagnostics. I use a power brick to power the drive and directly connect a SATA to eSATA cable.
