miogpsrocks
May 21, 2015Tutor
Seatools failing everything connected to USB docking station
The first 2 drives I tested from my readynas(with boot issues) resulted in saying that both drives had failed the short test. I thought I was in trouble then I tested it with an older version of the s...
BaJohn
May 26, 2015Virtuoso
Doesn't this mean that current that is being used in the drive is from 2 different power supplies (your brick for 12/5 volts and laptop for data)? I appreciate that this may work, but isn't that technically not a good thing to do?
StephenB wrote:
mdgm wrote: Personally I don't use an enclosure with eSATA for drive diagnostics. I use a power brick to power the drive and directly connect a SATA to eSATA cable.
