zimmfor's avatar
zimmfor
Setting up ReadyCLOUD on ReadyNAS Account permission issues
Hi Everyone,
When I try to setup ReadyCloud on our new ReadyNAS it says a local user account with the same username already exists use a different account. I want to use the account I am trying to set up, already a ReadyCLOUD account,  and not make the local accout a cloud account because of Egynte sync permissions.
Any suggestions on ways around this issue?
Thanks in Advance!
  • zimmfor's avatar
    zimmfor
    May 23, 2019
    Thank you for the update, I will come up with an alternative plan.
  • Unfortunately, there is no simple work-around.  Netgear has chosen that a ReadyCloud user and a local user cannot be the same.  They must have separate logins and separate home shares.
    The only other option is to go a different route for remote access, using a VPN instead of ReadyCloud.
    • zimmfor's avatar
      zimmfor
ProSupport for Business
