XrayDoc88's avatar
XrayDoc88
Apprentice
Mar 31, 2020
Setting Up UPS With 628X Confusion
I've had my 628X plugged into a CyperPower UPS for years, but I've never actually gone through the steps to have the 628X power down gracefully during a power outage.  How do you do this?  When using...
  • Sandshark's avatar
    Mar 31, 2020
    Yes, if you just connect a USB cable, the UPS should be detected and installed, assuming it's a supported UPS (most Cyberpower with USB connection are).
    If your UPS is old and has only a serial cable, it's not supported.
ProSupport for Business
